10 years agoROM and RAM connection
Im trying to connect ROM with RAM blocks,for this Im write top level entity and connected output of ROM with RAM This is code for ROMLIBRARY ieee; USE ieee.std_logic_1164.all;
use STD.textio.all;
ENTITY sync_rom IS
PORT (
clock: IN std_logic;
address: IN integer range 0 to 511;
data_a_i: OUT integer range 0 to 255;
data_b_q: OUT integer range 0 to 255
END sync_rom;
ARCHITECTURE rtl OF sync_rom IS
BEGIN
PROCESS (clock)
BEGIN
IF rising_edge (clock) THEN
CASE address IS
WHEN 0 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 16 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 70 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN 400 =>
data_a_i <= 128;
data_b_q <= 128;
WHEN OTHERS =>
data_a_i <= 0;
data_b_q <= 0;
END CASE;
END IF;
END PROCESS;
END rtl;
This is code for RAM library ieee;use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dp_ram_rbw_scl is
generic (
DATA_WIDTH : integer := 256;
ADDR_WIDTH : integer := 256
port (
-- common clock
clk : in std_logic;
-- Port A
we_a : in std_logic;
addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0);
data_a : in std_logic_vector(DATA_WIDTH-1 downto 0);
q_a : out std_logic_vector(DATA_WIDTH-1 downto 0);
-- Port B
we_b : in std_logic;
addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0);
data_b : in std_logic_vector(DATA_WIDTH-1 downto 0);
q_b : out std_logic_vector(DATA_WIDTH-1 downto 0)
end dp_ram_rbw_scl;
architecture rtl of dp_ram_rbw_scl is
-- Shared memory
type mem_type is array ((2**ADDR_WIDTH)-1 downto 0) of std_logic_vector(DATA_WIDTH-1 downto 0);
shared variable mem : mem_type;
begin
-- Port A
process(clk)
begin
if(clk'event and clk = '1') then
q_a <= mem(conv_integer(addr_a));
if(we_a = '1') then
mem(conv_integer(addr_a)) := data_a;
end if;
end if;
end process;
-- Port B
process(clk)
begin
q_b <= mem(conv_integer(addr_b));
if(we_b = '1') then
mem(conv_integer(addr_b)) := data_b;
end if;
end if;
end process;
end rtl;
after this this I write TOP level entity library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all ;
use ieee.math_real.all ;
use ieee.math_complex.all ;
entity ROMRAM is
port (
data_b_q: OUT integer range 0 to 255;
ADDR_WIDTH : integer := 256;
clk : in std_logic;
q_b : out std_logic_vector(DATA_WIDTH-1 downto 0);
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
port(
end component;
Component dp_ram_rbw_scl is
generic (
port (
clk : in std_logic;
addr_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ;
data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ;
end component;
for all : sync_rom use entity work.sync_rom(rtl);
--for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
--Signal data_a_i: integer range 0 to 255;
--data_b_q_a: std_logic_vector(255 downto 0);--interanal signals
begin
--inst : dp_ram_rbw_scl port map ( addr_a=> addr_a,
--clk=> clk,we_a=>we_a,data_a=>data_a,addr_b=>addr_b,data_b=>data_b,we_b=>we_b);
q_a<= addr_a and data_a;
-- Component Instantiation
C1: sync_rom Port map (
clock => clock,
address =>address,
data_a_i =>data_a_i,
data_b_q =>data_b_q
C2: dp_ram_rbw_scl Port map (
clk=>clk,
we_a=>we_a,
addr_a=>addr_a,
data_a =>data_a,
q_a=>q_a,
we_b=>we_b,
addr_b=>addr_b,
data_b =>data_b,
q_b=>q_b
data_a_i<=to_integer ( unsigned (data_a));
data_b_q<=to_integer ( unsigned (data_b));
end rtl;
But this code doesnt work/Could you please give me some hints for solution? I want to connect data_a_i(ROM) with data_a(RAM) and data_b_q(ROM) with data_b(RAM) I get next errors Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_a" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "addr_b" must have actual or default value Error (10346): VHDL error at Vhdl2.vhd(70): formal port or parameter "data_b" must have actual or default value37 Replies
rom does not need data input or write. ram needs them so check your wiring again.
For RAM,I need to connect addr_a _b ports?with adddress port from ROM?and data_a and data_b?
now, I competed this code
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all ; entity ROMRAM is generic( DATA_WIDTHi : integer := 8; ADDR_WIDTHi : integer := 8); port ( CLOC: IN std_logic; ADD: IN integer range 0 to 511; --data_a : in std_logic_vector(DATA_WIDTHi-1 downto 0); --data_b : in std_logic_vector(DATA_WIDTHi-1 downto 0); --data_a_i : out integer range 0 to 255; --data_b_q : out integer range 0 to 255; --clk : in std_logic; we_ai : in std_logic; addr_ai : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_ai : out std_logic_vector(DATA_WIDTHi-1 downto 0); we_bq : in std_logic; addr_bq : in std_logic_vector(ADDR_WIDTHi-1 downto 0); q_bq : out std_logic_vector(DATA_WIDTHi-1 downto 0)); end ROMRAM; architecture rtl of ROMRAM is --- Component decalarartion Component sync_rom is port( clock: IN std_logic; address: IN integer range 0 to 511; data_a_i: OUT integer range 0 to 255; data_b_q: OUT integer range 0 to 255 ); end component; Component dp_ram_rbw_scl is generic ( DATA_WIDTH : integer := 8; ADDR_WIDTH : integer := 8 ); port( clk : in std_logic; we_a : in std_logic; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_a : out std_logic_vector(DATA_WIDTH-1 downto 0); we_b : in std_logic; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0) ; data_b : in std_logic_vector(DATA_WIDTH-1 downto 0) ; q_b : out std_logic_vector(DATA_WIDTH-1 downto 0) ); end component; for all : sync_rom use entity work.sync_rom(rtl); for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl); Signal data_a_i_i: integer range 0 to 255;--interanal signals signal dt_ai: std_logic_vector(7 downto 0); Signal data_b_q_i: integer range 0 to 255;--interanal signals signal dt_bq: std_logic_vector(7 downto 0); begin -- Component Instantiation C1: sync_rom Port map ( clock => CLOC, address =>ADD, data_a_i =>data_a_i_i, data_b_q =>data_b_q_i ); C2: dp_ram_rbw_scl Port map ( clk=>CLOC, we_a=>we_ai, addr_a=>addr_ai, data_a =>dt_ai, q_a=>q_ai, we_b=>we_bq, addr_b=>addr_bq, data_b =>dt_bq, q_b=>q_bq ); dt_ai<=std_logic_vector(to_unsigned(data_a_i_i,dt_ai'length)); dt_bq<=std_logic_vector(to_unsigned(data_b_q_i,dt_bq'length)); --data_a_i<= to_integer(unsigned(data_a)); --data_b_q<= to_integer(unsigned(data_b)); --data_a_i <= std_logic_vector(to_unsigned(data_a_i,data_a'length)); --data_a=> data_a_i_i end rtl; - Altera_Forum
how is it looks now?
--- Quote Start --- how is it looks now? --- Quote End --- code ok but overall idea unclear. What do you put in rom (with dual port output). You then address rom from outside and address ram from outside. What is the purpose. I also suggest (strongly) changing the name cloc to clock or clk just for consistency. check your rom code address range(now 0~255). - Altera_Forum
After this I want to add this block in fft_engine(http://opencores.org/project,versatile_fft)
In ROM when fft see the next add like 0,16,70,400 in this addresses we put 128 values,for other we put just 0 Data from ROM should go to the RAM - Altera_Forum
--- Quote Start --- After this I want to add this block in fft_engine(http://opencores.org/project,versatile_fft) In ROM when fft see the next add like 0,16,70,400 in this addresses we put 128 values,for other we put just 0 Data from ROM should go to the RAM --- Quote End --- But I expect a proper fft core to require just input stream +plus start of frame/end of frame etc. So why do you care about addressing issues you mentioned
