RiscFree Arria10 Ashling Sample project does not build
Hi
Are you importing a sample project for the HPS or the niosV?
Maybe the link below might be useful when importing the project.
Project Import for NiosV
Project import for HPS
https://www.intel.com/content/www/us/en/docs/programmable/730783/23-4/importing-hps-project.html
Jingyang, Teh
Hello Jingyang, Teh,
I am importing a sample project for the ARM HPS. The HPS link does not have any issues for the Agilex A53 sample which comes with a pre-built 'elf' file. However, if I apply the same steps for the Arria10 sample then the project does not compile as shown in the original post attachment(Arria10-a9-sum- Does not build.PNG) and if I go into the Arria10 Sample project 'Properties->c/c++ build->settings->Tool Settings', then it shows as blank(Arria10-a9-sum- Orphaned configuration.PNG) with an "Orphaned Configuration...." warning. and Since the project does not build then it cannot create a debug session. I was wondering if there are other steps for the Arria10 to work on RiscFree IDE. As a additional test, I did the same steps with Cyclone V sample project, which gets the same type of error.
The RiscFree IDE version that come with the "Intel Quartus Prime Standard Edition" is v23.4.1
Fernando
