Reversing a bus in SystemVerilog
Is there a way to reverse a bus in systemverilog?
I am trying to do:
genvar j;
generate
for ( j=0 ; j < 256 ; j=j+1 ) begin
out[j] <= in[256-j];
end
endgenerate
But when I compile in ModelSim I get the errors:
** Error: (vlog-13069) near "[": syntax error, unexpected '['.
** Error: (vlog-13205) Syntax error found in the scope following 'out'. Is there a missing '::'?
I cannot see what is wrong here. Can anyone more familiar with SV see what is wrong?
The problem is with the procedural assignment statement inside your generate loop. Assuming out is declared as a wire, you need to change it to
for (genvar j=0j<256;j++) assign out[j] = in[256-j];But there us a much simpler way of writing this without a loop using the streaming operator
assign out = {<<{in}};
1 Reply
- dave_59
