AWilc1
7 years agoReversing a bus in SystemVerilog
Is there a way to reverse a bus in systemverilog? I am trying to do: genvar j; generate for ( j=0 ; j < 256 ; j=j+1 ) begin out[j] <= in[256-j]; end endgenerate But when I compile in ...
- 7 years ago
The problem is with the procedural assignment statement inside your generate loop. Assuming out is declared as a wire, you need to change it to
for (genvar j=0j<256;j++) assign out[j] = in[256-j];But there us a much simpler way of writing this without a loop using the streaming operator
assign out = {<<{in}};
dave_59
7 years agoThe problem is with the procedural assignment statement inside your generate loop. Assuming out is declared as a wire, you need to change it to
