14 years agoResource consumption
Dear my friends
I checked an adder, multiplier and a divider. All of them used LPM library. This is my code of Adder:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_arith.all;
USE IEEE.std_logic_signed.all;
LIBRARY lpm;
USE lpm.LPM_COMPONENTS.ALL;
ENTITY Add IS
port (CLK,CLK_40n : IN STD_LOGIC;
X1 : IN STD_LOGIC_VECTOR(15 downto 0);
A1 : IN STD_LOGIC_VECTOR(15 downto 0);
Y : OUT STD_LOGIC_VECTOR(15 downto 0)
END Add;
ARCHITECTURE Add_arch OF Add IS
SIGNAL adda,addb,addr,addrs :STD_LOGIC_VECTOR(15 downto 0):=(others =>'0');
SIGNAL CNT :STD_LOGIC_VECTOR(7 downto 0):=(others =>'0');
SIGNAL overflow, cout : STD_LOGIC:='0';
BEGIN
adder1: lpm_add_sub
generic map(lpm_width=>16,LPM_REPRESENTATION=>"SIGNED",lpm_pipeline=>1)
port map(dataa=>adda,datab=>addb,clock=> clk,overflow=>overflow,
cout=>cout,result=>addr);
GEN:block
BEGIN
PROCESS(CLK_40n)
BEGIN
IF CLK_40n'EVENT and CLK_40n='1' THEN
CNT<=CNT+1;
IF CNT=X"00" THEN
adda<=A1;
addb<=X1;
ELSIF CNT=X"01" THEN
Y<=addr(15 downto 0);
CNT <=X"00";
END IF;
END IF;
END PROCESS;
END BLOCK GEN;
END Add_arch;
And this is the code of Multiplier:
LIBRARY IEEE;
LIBRARY lpm;
ENTITY Mult IS
END Mult;
ARCHITECTURE Mult_arch OF Mult IS
SIGNAL mula,mulb :STD_LOGIC_VECTOR(15 downto 0):=(others =>'0');
SIGNAL mulr :STD_LOGIC_VECTOR(31 downto 0):=(others =>'0');
BEGIN
mull: lpm_mult
generic map(LPM_WIDTHA=>16,LPM_WIDTHB=>16,LPM_WIDTHS=>16,LPM_WIDTHP=>32,
LPM_REPRESENTATION=>"SIGNED",LPM_PIPELINE=>1)
port map(dataa=> mula,datab=>mulb,clock=> clk,result=> mulr);
GEN:block
BEGIN
PROCESS(CLK_40n)
BEGIN
CNT<=CNT+1;
IF CNT=X"00" THEN
mula<=A1;
mulb<=X1;
Y<=mulr(15 downto 0);
CNT <=X"00";
END IF;
END IF;
END PROCESS;
END BLOCK GEN;
END Mult_arch;
And this is the code of Divider:
LIBRARY IEEE;
LIBRARY lpm;
entity divide2 is
port(clk,clk_80n : in STD_LOGIC;
X1 : in STD_LOGIC_VECTOR(15 downto 0);
A1 : in STD_LOGIC_VECTOR(15 downto 0);
Y : Out STD_LOGIC_VECTOR(15 downto 0)
end divide2 ;
architecture divide2_ARCH of divide2 is
signal A,sat : STD_LOGIC_VECTOR(15 downto 0);
signal B : STD_LOGIC_VECTOR(15 downto 0);
signal cnt : STD_LOGIC_VECTOR(15 downto 0);
begin
m1: lpm_divide
GENERIC
MAP (LPM_WIDTHN=>16, LPM_WIDTHD=>16, LPM_PIPELINE=>1,
LPM_NREPRESENTATION=>"SIGNED", LPM_DREPRESENTATION=>"SIGNED")
port map (numer=>A,denom=>B,clock =>clk,quotient=>sat);
RC_TIME:block
begin
process(clk,clk_80n)
begin
if clk_80n'event and clk_80n='1' then
cnt <= cnt + 1;
if cnt= X"0000" then
A <= A1;
B <= X1;
elsif cnt= X"0001" then
Y <= sat;
cnt <= x"0000";
end if;
end if;
end process;
end block RC_TIME;
end divide2_ARCH;
The resource consumption: Adder is 77 logic elements. Multiplier is 61 logic elements. Divider is 410 logic elements. I don't know why the adder has the number of LEs more larger than Multiplier. Is it this code wrong? Thanks in advance
