Reset Release IP VHDL code not working
- 3 years ago
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
I do not know what should be a signal, a port, or something else. I am attaching my new code and errors. The Reset Release code is lines 13-27. I hope this looks better. I have tried to follow the tutorial for the Reset Release IP I found through Intel,
- sstrell2 years ago
Not seeing any attachments.
