MATRIX7878
3 years agoReset Release IP VHDL code not working
Hello, I am trying to create a simple VHDL design test for an Agilex 7 m-series FPGA and have hit a snag. I am trying to create a Reset Release IP code snippet and cannot seem to figure out wh...
- 3 years ago
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
MATRIX7878
3 years agoHello,
I did not do it right? The component and entity have the same name. Perhaps I am not seeing what you are saying. Could you please tell me what lines are not right. I have a rr_ip and resetRelease component and instantiation. Do I not need both?
Thank you,
Drew
