15 years ago --- Quote Start --- The quick way is to copy the last used command, actually this one :
qsta_utility::generate_top_failures_per_clock "Top Failing Paths" 200 onto the command line after the 'red' tcl> prompt and change the 200 into 10000 or so and hit 'enter'. There probably will be some to set that globally ... --- Quote End --- Hi, if you want to see all failing paths I would choose : Report all Core timings Report all I/O Timings The failing pahts will bemarked in red. For an quick overview I would use: Create All clock Histogramms Kind regards GPK
