9 years agoReplacing a process with 1-port RAM
i have process I need to now implement as ROM. process (count, outi, run) --converter
begin
if (run = '1') then -- run is a physical switch
case count is -- count ...
9 years ago --- Quote Start --- Count doesnt have an initial value, or a reset value, hence it will initialise (in simulation) to 'U' You also have other issues: 1. You should create logic divided clocks- they are prone to timing issues on hardware 2/ do not use "and" with the clock 3. its better to separate asynchronous and synchronous logic into different processes. --- Quote End --- I changed count to now be
signal count : std_logic_vector (1 downto 0) :="00"; 1. I'm sure what logic divided clock means. 2. I changed it and used if conditions instead. 3. I've done that also The output is still U for all of the U1 signals after running sim and count still initialises as U
