LChow3
2 years agoReplacement of ModelSim
In the past, I used ModelSim for functional simulation. I just started to use Quartus Lite v.23. During the EDA Tool Settings, do I choose QuestaSim or Questa Intel FPGA? How do I launch Que...
LChow3
2 years agoThanks for the link.
Last time when I used ModelSim, I used wave window to do the simulation. Is this still possible with the Questa?
I still couldn't find out where to launch the Questa if I'm not using testbench. Can you tell me the path to open Questa directly?
Thank you.
sstrell
2 years agoQuesta is very similar to ModelSim so yes to your first question.
Assuming you are talking about the version installed with Quartus, it would be available in the Start menu along with Quartus, unless you did not install it. It is an optional install on top of Quartus.
- LChow32 years ago
I can find it in the Start menu (below), but when I click on it, nothing appear.
I have already set the following in the EDA Tool Settings:
