LKrup
7 years agoRename Platfor Designer system
Hi, is there a simple way to change the name of the entire platform designer (qsys) system along with the names of included ip cores and their paths?
- 7 years ago
I am using Quartus 18.1.2 Pro edition and unfortunately archiving system is doing exactly what it is in its name - gather all .ip and .qsys files in zip file, unzipping doesn't change anything.
Only way that I found is by manually rename every IP in system by right click ->"Rename IP Variant File ...", then move all sub IP's files to folder with new name, then by right click ->""Edit Generic Component" set new IP's files paths manually for every file and then at the end change main .qsys file name manually in operating system.
For bigger systems it is lot of clicking, is there simpler way (question from first post)?
JHill1
1 year agoA development tool imposing a restriction on renaming the source file?
