FRoth
6 years agoRemoving existing set_false_path netlist assignments
We have a set_clock_groups command, specifying false paths between clocks. Is it possible to remove a set of false paths from this set, fulfilling a given condition? That means, reverting a set_false...
KhaiChein_Y_Intel
6 years agoHi,
Could you share the error message and the version that the reset_path is working?
KhaiY
- FRoth6 years ago
There is a SDC parsing error in TimeQuest (Unknown option: -reset_path). Looking into the TQ documentation, the -reset_path option is not supported. The older version I was referring to was from quite a long time ago and I cannot seem to find the reference now. Is there any similar command, which could remove existing false path assignments from a set of nets in netlist?
Thank you
Filip
- KhaiChein_Y_Intel6 years ago
Upon checking, there is no command to reset the path. you have to use set_false_path to remove the paths from timing analysis in this case.
Thansk.
KhaiY
