15 years agoI used to hack my system reset by adding in another 'soft reset' case by instantiating the 'constant' megafunction in my design and parameterizing it to support in-system memory editing. It basically hooks up a lookup table to JTAG so that you can flip the contents between '0' and '1'. Then you connect to a live system using the in-system memory editor and modify the value.
