15 years agoDesigners can reset the fpga remotely using soft reset, obviously provided you have software control. Otherwise I suggest two options:
1) use in-system memory editor to write to a register which is hardwired to be ORed with your master reset. 2) I normally don't need reset as i include user power up reset to follow the fpga reset release as the latter is unreliable at release.
