15 years ago
remote update & parallel flash no longer works in 10.0sp1?
I've got a couple different projects that use a Cyclone-III part and active parallel configuration. These projects use a remote update module to allow for field upgrades.
All was well until I tried to build the design after updating to 10.0sp1. Now my fit fails with the error:
Error: Remote update block is operating in remote update mode -- configuration scheme is not Active Serial programming mode
I've got a support request in to Altera, but no response after a few days.
Any suggestions?
    Received a response on the service request I had filed for this. Turns out that this is a bug in 10.0sp1, presumably it will be fixed in sp2.
    The problem effects Cyclone III and IV-E devices. With 10.0sp1 you can't have a remote update block on a design that uses active parallel configuration mode.
    Not sure if the problem is specific to Linux versions of Quartus or if it also effects the Windows version.
    Altera gave me a patch (thanks) which got be back up and running. I'm sure sp2 will be out shortly to correct this.
    May I have this patch, too..:)?
    I got the same problem...:rolleyes:
    i think the fix is in Quartus II 10.0 SP1 Patch 1.113, you can request it in a service request in the mySupport section of Altera's site
    Hi, now i have the same problem.
    I have to use the Remote Update configuration scheme with Quartus 10Sp1 on a Cyclone III.
    I have request a service request to Altera.
    Now i'am waiting for answer.
    Can i download the patch from the web too? Does the patch work?
    Am experiencing same problem in 10.1..... Does anyone else have this problem?
