Umasree
5 years agoregarding Quartus Prime
while synthesising verilog rtl its showing unavailable memory to synthesis and its taking nearly 10min for synthesising process.please check on that issue.
SyafieqS
5 years agoHi Umasree,
Make sure your RAM meet the requirement for you project in term of device you used. I believe this could be due to this. Not able to run any project at all is very weird, supposed small design can pass the flow even you have a small RAM. Suggestion is to reinstall and check all requirement is met. Another way, try to clean .cdb file and database and recompile.
