regarding Quartus Prime
while synthesising verilog rtl its showing unavailable memory to synthesis and its taking nearly 10min for synthesising process.please check on that issue.
- sstrell
How much RAM do you have? I'd also suggest removing the spaces from your project path. I doubt that's the issue, though.
And it looks like synthesis is working but not the Fitter. Are you able to fully compile any projects at all? Could be a bad Quartus install.
- Umasree
Am not able to run any of the projects.problem is with compile design and cleared chache.still it is not working
- SyafieqS
Hi Umasree,
Make sure your RAM meet the requirement for you project in term of device you used. I believe this could be due to this. Not able to run any project at all is very weird, supposed small design can pass the flow even you have a small RAM. Suggestion is to reinstall and check all requirement is met. Another way, try to clean .cdb file and database and recompile.
