Umasree
5 years agoregarding Quartus Prime
while synthesising verilog rtl its showing unavailable memory to synthesis and its taking nearly 10min for synthesising process.please check on that issue.
sstrell
5 years agoHow much RAM do you have? I'd also suggest removing the spaces from your project path. I doubt that's the issue, though.
And it looks like synthesis is working but not the Fitter. Are you able to fully compile any projects at all? Could be a bad Quartus install.
- Umasree5 years ago
Am not able to run any of the projects.problem is with compile design and cleared chache.still it is not working
