14 years agoDear sir,
Thank you. Ya agree with you. Consider in the case of ASIC, we will be increasing the REG count due to altera's routing technique. Here the problem is with area also, which should be min. If all the options are closed then, we have to go for REGISTERING. But still I believe there is some command is there to get solve this problem. Thanks and Regards, Manju.P
