17 years agoThank you for the update, it didn't solve the problem I was seeing but did point to the problem. The heap was the tip, there is a /3Gb switch you can pu tin the boot.ini to unlease >2G in windows for Quartus to utilize installed memory. This switch was causign the heap problem.
thanks for the help! Sean....
