Setting design partitions and logiclock regions can make significant improvements to your run time by only recompiling the blocks that have changed.
Also the compilation time advisor will be able to recommend settings that will improve run time. - Altera_Forum
Using smart compilation will also improve run time (refer to Assignments>Settings>Compilation Process Settings.)
--- Quote Start --- Simple one: Has anybody any tips or suggestions as to how to improve Quartus run times? --- Quote End --- The quartus handbook (http://www.altera.com/literature/hb/qts/qts_qii52005.pdf) has lots of suggestions here. Start at page 10-64. Cheers, Adrian Ludwin Altera Corp.
