15 years ago
Reduce oscillator frequency
I have timing problems in Quartus and got suggested to reduce my oscillator frequency. Is this possible through Quartus? I'm using a DE0-boards, Cycylone III.
Thanks a lot.
mr_embedded
    The DE0 has a 50MHz oscillator built in. If this is too high you could create a clock divider circuit in HDL or use a PLL from the Altera MegaCore package that comes with Quartus.
    Thank you,
    I guess there is no simple solution like clicking a CLOCK DIVIDE BY 2 or something in Quartus.
    // mr_embedded
    --- Quote Start ---
    employ megawizard pll primitive
    --- Quote End ---
    The Altera DE2 has on-board 27 MHz and 50 MHz physical oscillators. Using the ALTPLL (or just the PLL), I can divide to the minimum clock frequency of 9.375 MHz (although the claimed minimum is 10 MHz). My question is how can I get a 5 MHz frequency? I know I can use an external clock through the SMA connector, but is there an on-board solution to solve this problem?
    thanks.
    Jack
    You can keep a 10MHz clock and use a clock enable signal that is only active on half the cycles.
