12 years agoHi, when you use SignalTap, you have a switch named "Allow all changes / allow triggers changes only" (something similar) above the data settings in order to not recompile the whole
BUT you can't change the signal set anymore except triggers, transitional save... Put a wide set of signal, after you will opt what you want. In Quartus 12.0sp1, I face to a little problem : SignalTap sometimes does not recognize my trigger conditions, I have to save and reload.
