Received ERROR while using XCVR_TX_COMMON_MODE_VOLTAGE for Arria5 GX Transceiver
Using Documentation Link:
Says I should be able to set this in the QSF file with a set_instance_assignment. The device I am using is:
5AGXFB3H4F35C4
Quartus Version: 21.1.0.842 on Linux
Command example in my QSF file:
Error from Quartus when processing:
This error occurs during FIT so the QSF parser thought the command was OK. I did try a value found for the XCVR_RX_COMMON_MODE_VOLTAGE which was VTT_0P35V and the QSF parser said it was illegal.
So the question is? Can I make this assignment? And if so what are the legal accepted values by the Fitter for the device I am using? I am using a custom data rate and protocol so please don't ask me to choose one of the existing profiles -- they will not work in this situation. Also I cannot upload the design -- the best you get is screen shots like above; company policy ;-(
- ZiYing_Intel
Hi Thomas,
May I know the value of data rate and VCCR_GXB/VCCT_GXB that you used in the design?
Zi Ying
- ZiYing_Intel
Hi Thomas,
Hope that the link below is useful to you. https://www.intel.com/content/www/us/en/support/programmable/articles/000081690.html
zying
- ThomasTessier
Do you have information for the Arria5 GX part as I pointed out that was what I was using?
Second can we change this value either in the QSF or via XCVR Reconfiguration Registers?
TomT...
- ZiYing_Intel
Hi Thomas,
For the information about the Arria V GX, you may refer to link below https://www.intel.com/content/www/us/en/support/programmable/articles/000079138.html
Hopefully the link is useful to you. Please do let me know if you unable open the link.
Zi Ying
- ZiYing_Intel
Do you still have any question about this case?
Zi Ying
- ThomasTessier
I think I understand and have moved on.
TomT...
- ZiYing_Intel
since user don't have further question, I am now close the case. If user got any further question after the case closed, please do feel free to submit another issue.
