13 years agorenaming it .dat wont make a difference - it will still be a text file. You would have to regenerate the file writing the values direct to 32 bits rather than text values.
The error is becuase you have read in an empty line, or you're trying to read past the end of a line. are you sure you have all the dimensions correct?
