18 years agoreading from RAM
Hi
I implemented the following ram: getting_data:process(clk) begin if rising_edge(clk) then if wr_en='1' then array_data(conv_integer(address_write1))<=data_in; else data_out1<=array_data(conv_integer(address_read1)); end if; end if; end process; I write data to the RAM with address_generator in other file (top-level): address_write1<=address_write1+1... and read data with address_read1<=address_read1+1 In modelsim it works perfect but after timing simulation I never managed to read data in right way... (*vho,*.sdo) need help to read data (I think it should not be difficult)... :confused: thanks ari
