14 years agoHi again,
I ran the example design as you suggested but the problem is same. Every time a write command is issued (as it says on the transaction screen with blue text) a BAD WRITE is replied in the next line. And whenever it reads, all 0's are read. And when it compares the written and read data it stops with the message that simulation failed. I am sure the write operation is somehow causing the problem. The BAD WRITE also appears in my case, any suggestions now?
