15 years ago
Read from a text file
I'm trying to read a text file with VHDL to generate some automatic input codes.
I made a project just to test this entity, but my output is always with value 'Z'.
my text file contains only one line and the line contains this
"11111111"
Observation : the cod.txt was created with QuartusII and is included to the project!
i think quartus can't open or read the file or something like that
thanks in advance
library std;
library ieee;
use std.textio.all;
use ieee.std_logic_1164.all;
entity readfile is
    port(clock : in std_logic;
         --output : out std_logic_vector(7 downto 0);
end readfile;
architecture logic of readfile is
--signal aux: std_logic_vector(7 downto 0);
begin
    process(clock)
        variable inline:line;
        variable character_variable:character;
        variable end_of_line:boolean;
        file myfile:text is "cod.txt";
    begin
        if(clock'event and clock = '1') then
            readline(myfile,inline);
            read(inline,character_variable,end_of_line);
            for i in 0 to 7 loop
                case character_variable is
                    when '0' =>
                        output <= '0';
                    when '1' =>
                        output  <= '1';
                    when others  =>
                        output  <= 'Z';
                end case;
            end loop;
            --output <= aux;
        end if;
    end process;
end logic;
    Ohhhhhhhhhhhhhhhhh
    so the problem is the Quartus Software...
    the modelSim from altera can read it then?
    --- Quote Start ---
    --- Quote End ---
    Read the above posts... everything has been said.
    P.S.: The Atera edition has all basic ModelSim features.
