Timing constraints for external logic that takes input from, and outputs to an FPGA
For the synchronous I/O external device:
Check this virtual class link https://learning.intel.com/Developer/learn/courses/841/intelr-quartusr-prime-pro-software-timing-analysis-part-4-io-interfaces/lessons/1506:99/intelr-quartusr-prime-pro-software-timing-analysis-part-4-io-interfaces (page 18-29) and this link https://community.intel.com/t5/FPGA-Wiki/Timing-Constraints/ta-p/735562 on set_input_delay and set_output_delay.
For the constraints, just need to know the board delay(max/min), board clock skew(max/min) and external device's tsu, th, tco(max/min) will do. The FPGA's internal propagation delay will be handled and calculated by the tool itself.
Sheng
I haven't found an answer to this yet. Where else can I go for answers to this question? Is there someone at Intel that would know more?
