skyviper
2 years agoQuestasim vdel
Questasim can't delete libraries using the vdel command. Each time I attempt to use the vdel command (GUI or Tcl), I get the following: vdel -all -lib tb_lib_path # wrong # args: should be "compi...
TingJiangT_Intel
Contributor
1 year agoBTW, I have submit this issue to the engineer. If any updates, we will inform you.
You can try to reinstall the Quartus (with Intel Questa), and make sure all antivirus, antimalware are turned off, as it may related to the software corruption,
