ElShang's avatar
ElShang
28 days ago
Quartus Prime Lite 25.1 - Issue with the Verilog generate loops
Hi! I believe, this is the same issue mentioned here, or at least its sibling. Long story short, here is a snippet from the IEEE Std 1364™-2005 standard, page 185: module addergen1 (co, sum, a, b,...
  • FvM's avatar
    27 days ago
    Hi ElShang,
    there's a change in generate block specification from Verilog 2001 to 2005. Verilog 2005 states (12.4 Generate constructs, page 181)
    The keywords generate and endgenerate may be used in a module to define a generate region. A generate
    region is a textual span in the module description where generate constructs may appear. Use of generate
    regions is optional. There is no semantic difference in the module when a generate region is used.
    Verilog 2001 requires generate - endgenerate (12.1.3 Generated instantiation, page 169)
    All generate instantiations are coded within a module scope and require the keywords generate - endgener
    ate.
    Quartus Prime Std implements only Verilog 2001 and not exactly defined Subset of System Verilog.
    In Quartus Prime Pro, the keywords are optional as you expect.
    Frank
