mevenson
1 year agoMegaWizard Plug in Manager GUI ipdate for Windows 11
Are there any plans to fix the GUI interface for MegaWizard Plug in Manager so that the contents of the dialog fit in the dialog box without resizing. The 'Cancel', 'Back', 'Next' and 'Finish' button...
mevenson
1 year agoFrank,
Thanks for responding. What specifically do you not understand about the comments I made? In my initial post, I show a screen shot of the windows after it opened and it clearly shows that the vertical size of the window is not large enough to display the buttons on the bottom of the window without resizing. My screen resolution is 3840 X 2160 on a 28" BENQ monitor with the scaling factor set to 150%. When I set the scaling factor to 100%, it has the same problem, so it is not scaling that is the issue.
I realize that I can resize the window after it opens, but in a well designed GUI, I should not have to. My question to the developers of the wizard is - will this be fixed any time soon?
