NTA
1 year agoHow to configure Dual Compressed Images on MAX10 without IP core?
Hello, we have a PCB with a MAX10 FPGA (M50SAE144I7G) and would like to make use of the dual configuration feature. The PCB features a switch that pulls the FPGA's dedicated config_select pin to HI...
- 1 year ago
Hi there,
What you are encountering now seems to be a config issue. It looks like the previous problem with sof -> pof conversion has been resolved. Unfortunately, the root cause of the failure is still unclear. So I would like to further confirm the following:
- Loading the standalone sof file included in the pof works fine, right?
- In step 6, the CPF mode is set to Internal Configuration.
- Does the Programmer show any specific error messages?
- If you reduce the JTAG speed to 6 MHz in the Programmer, does it help to resolve the issue?
WZ
WZ2
1 year agoHi there,
WZ
