HongLiang
3 years agoHDMI example an not change the device in V22.4 for aglixe FPGA
We try to use the EVB to test the HDMI function
We generate the HDMI EXAMPLE from Quartus 22.4 following the HDMI doc step
we change the device ID in step 10 but the result is still kep...
HongLiang
3 years agoHi
May I clarify with you below items:
Q1. Which Quartus version you are using?
22.4
Q2. Which OPN you intend to use?
there are 2 OPN we will use
AGFB027R31C2E1V AGIB027R31B1I1V
Q3. May i know which design example variant and settings you want to generate?
we will need HDMI TX /RX SDI TX/RX DP TX/RX
I try to use op1(intel recommand)
step1. create a whole new project for AGFB027R31
step2. call the HDMI IP -->set the hdmi in TX and AXIS mode to generate
setp3. generate the example IP
but I still see the example target ID is not the same as the project OPN
HongLiang
3 years agoHi
maybe you guys can try to find a way or step to create the AGFB027R31C2E1V HDMI example
