16 years agoEThernet Blaster protocol
Hi, I'm looking for Ethernet blaster protocol. Could you help me ? I would like to have debug interface from Quartus/Nios IDE to remote HW. Is there an any chance to find such description ...
aesq
2 years agoAt my side I use an Ethernet blaster II that works fine when connected to a Cyclone V FPGA.
I can run the Quartus programmer/signal tap from either Linux or Windows.
For this a Fix IP address is dedicated to the MAC address of the Ethernet blaster 2.
To be noted that the Ethernet blaster 2 is only stable using a 100 Mpbs network setting
and where the" fast port" switch ethernet option is turned off (otherwise the connection is being lost after few seconds).
