Analysis & Synthesis Error(13224): Verilog HDL or VHDL error "..:" index -8 is out of range [15:0]..
Hi @Ranesh ,
Internal Feedback:
For the expression if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty)))
1. When "s_in_empty" is of type logic, the expression in if condition can't be evaluated at compile time. So all possible indices are generated for "s_in_data".
e.g., for value of c = 18 onwards, index for s_in_data becomes negative.
Let me further check with expert on the second example you provided.
Sheng
Hi Sheng,
Please note that the expression if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty))) is bound by the expression for (int c = c_IN_DESC_BYTE_CNT; c < c_OUT_DATA_BYTE_CNT; c++). This limits c not to be below c_IN_DESC_BYTE_CNT, which is 26. So in the expression s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8], which is bound by the expression that you have mentioned, c can only be 26 or 27, because s_in_empty is single bit signal and c_IN_DATA_BYTE_CNT = 2.
I am re-attaching my explanation in word document for you and the expert
Ranesh
