16 years agoRapid recompile
Anybody tried the rapid recompile feature in Quartus 9.1?
With rapid recompile feature switched on: I took a unpartioned flat design on an 80% full EP4SGX230 Stratix device and ran it through and it took 1hr 42min. I then changed the reset value from '0' to '1' in the vhdl for just one register and ran it though again. This time it took 1hr 36min. Not what I was hoping, although hardly conclusive on just one design. Am I missing something? I'd be glad to hear of anyones experiances with this feature.15 Replies
Its my understanding the rapid recompile is really for very small design changes away from critical parts of the design, kind of like ECO changes but the code changes are now completely annotated.
Changes should be very minor like a bit flip or one pin change. I ran some tests yesterday on a DDR2 design, 3 test cases Minor edit to code (no functional change) Register logic flip Pin move All three resulted in about the same benefits A&S about 10% faster Fit about 50% faster Timing about 20% faster Assembler about 10% faster - Altera_Forum
I Installed the last 9.1 sp2 vesrion but the "rapide recompile" option is not selectable ! "OFF" is the default and I can't click on the 2 other options ! Is it device dependent ? my device is a statix EP1S20 - Altera_Forum
Read MarkB's post thoroughly. Stratix I is unsupported.
can someone tell me which menu I can find this setting under?
EDIT: just found it under settings Compilation Process Settings Incremental Compilation - Altera_Forum
In Quartus Prime 17.1.0 you can find the Rapid Recompile Option in the menu under:
Processing/Start/Start Rapid Recompile Kind regards.
