18 years agoOK, I have found out why my project wont download.
Simple project with: CPU OnchipMem JTAG UART Works fine. :) Product Project with: CPU Onchipmem JTAG Tristate Bridge / FLASH & SDRAM DM9000 Network interface UARTS x9 IO Watchdog etc. No Worky :( If I remove the Tristate bridge, the project works fine! Even in SOPC 7.1 with SP1 to get rid of the huge 'Java error' problem it fails to download. I have also noticed a bug with the Tristate bridge wizard - about 50% of the time the initial screen which asks you if you want a registered or non registered interface will not render the Registered button, so the only option you see is Not registered. So I can only guess my problem is with the new tristate bridge. Sadly I need to get a product out ASAP which needs it so I have been advised by my FAE to roll back to 7.0
