11 years ago --- Quote Start --- Yes you cannot initialize a array which is defined in vhdl as type array ( 0 to 15) of std_logic_vector( 15 down to 0 ), but you can initialize a ROM/RAM with .mif file , i have done with .mif generated using Matlab . --- Quote End --- You can easily initialise a rom with a function or a constant, no matter what the type declaration. Check the altera coding guidelines. I don't think I fully understand the ops problem. It sounds like all you need is a rom that is setup using a vhdl function.
