You can define a RAM module in Megawizard with properties equal to RAMB4_S16_S16.
You would get a component definition like this
component altRAMB4_S16_S16
PORT
address_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
address_b : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
clock_a : IN STD_LOGIC ;
clock_b : IN STD_LOGIC ;
data_a : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
data_b : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
enable_a : IN STD_LOGIC := '1';
enable_b : IN STD_LOGIC := '1';
wren_a : IN STD_LOGIC := '1';
wren_b : IN STD_LOGIC := '1';
q_a : OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
q_b : OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
end component;
In the
wrapper architecture, you instantiate this module using the RAMB4_S16_S16 port names:
RAMB4_S16_S16_inst : altRAMB4_S16_S16 PORT MAP (
address_a=> ADDRA, -- Port A 8-bit address input
address_b=> ADDRB, -- Port B 8-bit address input
clock_a => CLKA, -- Port A clock input
clock_b => CLKB, -- Port B clock input
data_a => DIA, -- Port A 16-bit data input
data_b => DIB, -- Port B 16-bit data input
enable_a => ENA, -- Port A RAM enable input
enable_b => ENB, -- Port B RAM enable input
wren_a => WEA, -- Port A RAM write enable input
wren_b => WEB, -- Port B RAM write enable input
q_a => DOA, -- Port A 16-bit data output
q_b => DOB -- Port B 16-bit data output
In the wrapper entity, you export the RAMB4_S16_S16 port names. You could shorten this action by simply renaming the ports in the wizard generated designfile, but then it could be no longer edited by the Megawizard.
