OK, THX, Now I use process to detect edge in signal done_ps2 and Quartus accepted this structure, but in other file i detect 2 edge in one clock. How else solve this probelm?
--registers
process (clk20khz, rst)
begin
if rst = '0' then
Present_State <= ST_idle;
c_reg <= (others => '0');
b_reg <= (others => '0');
n_reg <= (others => '0');
elsif (clk20khz'event and clk20khz ='1') then
Present_State <= Next_State;
c_reg <= c_next;
b_reg <= b_next;
n_reg <= n_next;
end if;
end process;
--odd parity bit
par <= not (dane_we(7) xor dane_we(6) xor dane_we(5) xor dane_we(4) xor
dane_we(3) xor dane_we(2) xor dane_we(1) xor dane_we(0));
process(Present_State, n_reg, b_reg, c_reg, dane_we, par, fall_edge, start, clk20khz)
begin
---Next_State <= Present_State;
c_next <= c_reg;
n_next <= n_reg;
b_next <= b_reg;
ps2c_out <= '1';
ps2d_out <= '1';
tri_c <= '0';
tri_d <= '0';
case Present_State is
when ST_idle =>
done <= '0';
if start = '1' then
b_next <= par & dane_we;
c_next <= "0000010"; -- wait 100 us
Next_State <= ST_rts;
else
Next_State <= ST_idle;
end if;
when ST_rts => -- request to send
ps2c_out <= '0';
tri_c <= '1';
c_next <= c_reg - 1;
if(c_reg = 0) then
Next_State <= ST_start;
end if;
when ST_start => -- assert start bit
ps2d_out <= '0';
tri_d <= '1';
ps2c_out <= clk20khz;
tri_c <= '1';
if (falling_edge(clk20khz)) then
n_next <= "1000";
Next_State <= ST_data;
end if;
when ST_data => -- 8 data + 1 parity
ps2d_out <= b_reg(0);
tri_d <= '1';
tri_c <= '1';
b_next <= '0' & b_reg(8 downto 1);
if n_reg = 0 then
Next_State <= ST_stop;
else
n_next <= n_reg - 1;
end if;
end if;
when ST_stop => -- assume floating high for ps2d
done <= '1';
end if;
end case;
end process;
-- tri_state buffers
CLOCK_PS_OUT <= ps2c_out when tri_c = '1' else 'Z';
DATA_PS_OUT <= ps2d_out when tri_d = '1' else 'Z';
