15 years agoI did this about a year ago in Stratix 3. I generated 3 megafunction blocks:
- alt_dq_dqs - altiobuf_bidir (for the data bidirs) - altiobuf_in (for dqs and dqsn) 1. The dq_dqs mf block had the DQ_GROUP statements embedded in it (I may have needed to switch between DQ_GROUP 18 and 9 - I'm a tad fuzzy on that recollection). 2. I'm fairly sure it's dedicated routing. 3. CQn should also be on the dedicated routing... in my design, cq/cqn both came through the altiobuf_in cells, then connected to the dqs_input_data_in and dqsn_input_data_in pins of alt_de_dqs. The dqs_bus_out/dqsn_bus_out pins are left unconnected. I then used an internal clock as a transfer clock, connected ot the dq_ipa_clk pin. I only have some of the info on how I did this, as I'm not at that job anymore, so don't have access to my notebooks.
