17 years agoI think, most of your questions can be easily answered by trial. Did you notice the option, to name the signals ("wires") in your schematic? You have to use a correct bitwidth for bus signals, however. When you convert the schematic to VHDL afterwards, you'll see, that this is what your asking for. Synthesized_wire_xx signal names are used for unnamed signals only.
--- Quote Start --- Do I need to create a VHDL file for each page? --- Quote End --- Each schematic is representing a design entity. You can replace no, some or all schematic entities by VHDL design entities in your design, as you like. The design's integrity should be kept anyway.
