10 years ago
Question on return result from a function
I am good at Verilog but I have a project where I need to review VHDL so this might be a simple question but I haven't found an answer yet. What does the function below return when n>1?
Chris
function f_sub_clamp(a : std_logic_vector; b : std_logic_vector; constant LEN,n : integer) return std_logic_vector is
variable A_SZ : integer := a'length;
variable B_SZ : integer := b'length;
variable a2 : std_logic_vector(A_SZ-1 downto 0);
variable a0, a1 : std_logic_vector(A_SZ/2-1 downto 0);
variable b2 : std_logic_vector(B_SZ-1 downto 0);
variable b0, b1 : std_logic_vector(B_SZ/2-1 downto 0);
begin
if n>1 then
a2 := a;
a1 := a2(A_SZ-1 downto A_SZ/2);
a0 := a2(A_SZ/2-1 downto 0);
b2 := b;
b1 := b2(B_SZ-1 downto B_SZ/2);
b0 := b2(B_SZ/2-1 downto 0);
return f_sub_clamp(a1, b1, LEN/2, n/2) & f_sub_clamp(a0, b0, LEN/2, n/2);
elsif unsigned(a)>unsigned(b) then
return ext(unsigned(a)-unsigned(b), LEN);
else
return ext("0", LEN);
end if;
end function;
    This seems like a massively over complicated function. At then end, it appears to just return either a-b, with a load a and b appended to it when a > b or just 0 with a load of a and b appended to it. I really suggest you simulate it to see what it really does.
    It also appears to be non-standard VHDL. given the use of the ext function, I guess it's using the non-standard std_logic_arith library?
    It looks like the "return" is calling the function itself? I guess it is possible because it runs in hardware. I guess I will simulate this to see what it does?
