13 years agoquestion about writing testbench
Hi all,
I wrote a testbench for a full adder. However, the testbench doesnt work. The function of the testbench is, that it tries to read input stimulis from a file called fa_in.txt and output results to a file called fa_out.txt. The error is, that entity fa wrote nothing to output file fa_out.txt, and there is no any waveform in Modelsim editor. The input file looks like: ----file begins---- 000 001 010 011 100 101 110 111 ----file ends---- after simulation, the output file should looks like: ---file begins---- 1.000---->00 2.001---->01 3.010---->01 4.011---->10 5.100---->01 6.101---->10 7.110---->10 8.111---->11 ---file ends---- Can anybody shed some light on my code? Thanks. ----VHDL code for full adder---- library IEEE; use IEEE.STD_LOGIC_1164.all; entity fa is port( CIN,A,B:in BIT; COUT,SUM: out BIT); end fa; architecture fa_behavior of fa is begin process(CIN,A,B variable TEMP_COUT,TEMP_SUM:BIT; begin case CIN&A&B is when "000" =>TEMP_COUT:='0';TEMP_SUM:='0'; when "001" =>TEMP_COUT:='0';TEMP_SUM:='1'; when "010" =>TEMP_COUT:='0';TEMP_SUM:='1'; when "011" =>TEMP_COUT:='1';TEMP_SUM:='0'; when "100" =>TEMP_COUT:='0';TEMP_SUM:='1'; when "101" =>TEMP_COUT:='1';TEMP_SUM:='0'; when "110" =>TEMP_COUT:='1';TEMP_SUM:='0'; when "111" =>TEMP_COUT:='1';TEMP_SUM:='1'; end case; COUT<=TEMP_COUT;SUM<=TEMP_SUM; end process; end fa_behavior; ----VHDL code ends---- ----testbench code---- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use STD.TEXTIO.all; entity TB_fa is end; architecture IO_EXAMPLE of TB_fa is component fa port (CIN,A,B:in BIT;COUT,SUM: out BIT); end component; file VEC_FILE:TEXT open READ_MODE is "c:/fa/fa_in.txt"; file RESULT_FILE:TEXT open WRITE_MODE is "c:/fa/fa_out.txt"; signal S: BIT_VECTOR(0 to 2); signal Q: BIT_VECTOR(0 to 1); begin TB_fa: fa port map (S(0),S(1),S(2),Q(0),Q(1)); process constant PROPAGATION_DELAY:TIME:= 2 ns; variable BUF_IN,BUF_OUT:LINE; variable OUT_STR:BIT_VECTOR(0 to 1); variable NUM_VECTORS:INTEGER:=0; variable VAR_S:BIT_VECTOR(0 to 2); begin while not ENDFILE (VEC_FILE) loop READLINE(VEC_FILE,BUF_IN); assert(BUF_IN'LENGTH=3) report "Vector does not have three bits" severity ERROR; READ(BUF_IN,VAR_S); S<=VAR_S; wait for PROPAGATION_DELAY; NUM_VECTORS:=NUM_VECTORS+1; WRITE(BUF_OUT,NUM_VECTORS); WRITE(BUF_OUT,STRING'(".")); WRITE(BUF_OUT,S); WRITE(BUF_OUT,STRING'("---->")); OUT_STR:=Q; WRITE(BUF_OUT,OUT_STR); WRITELINE(RESULT_FILE,BUF_OUT); end loop; report "Completed processing all vectors."; wait; end process; end IO_EXAMPLE; ----testbench code ends----
