14 years ago
question about Quartus II 7.2 web edition license
Hi guys,
I have done a project under Quartus II 7.2 web edition(30-day evaluation mode). I intend to release a paper based on the project. So I am wondering how can I apply or purchase a license for it? Thanks.
    --- Quote Start ---
    --- Quote End ---
    Why not use a more recent version?
    You do not need to purchase a license for the tool to publish a paper.
    Cheers,
    Dave
    Hi Dave,
    Thank you for your reply. The reason why I prefer to use Quartus II 7.2 was it provided waveform editor. As I know, it has been canceled in later versions.
    Actually, I am about to write my thesis based on that project. Also, I need to pass all of the code and schematic to someone in the industry for review. So I am considering for purchase a license for the tool. Otherwise, I feel sort of "illegal" for not doing research on authorized tool. Could you give me any suggestions? Thanks.
    --- Quote Start ---
    --- Quote End ---
    For good reason. Hand drawing waveforms is not a good verification technique.
    If you would like to learn how to use Modelsim, I can get you started.
    There's VHDL testbenches here:
    http://www.alteraforum.com/forum/showthread.php?t=35572
    http://www.alteraforum.com/forum/showthread.php?t=32386
    and SystemVerilog ones here:
    http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
    --- Quote Start ---
    --- Quote End ---
    Great! Good luck with your writeup.
    Once you've described the design, post a link to the chapters, and source code, and people on this list can help review it.
    If the design is well explained, then getting a Modelsim simulation working should be straightforward.
    --- Quote Start ---
    --- Quote End ---
    You are already using an Authorized tool. Altera provide the web edition for you to use. You can post your design here, to me, or to anyone, and there is nothing illegal about it.
    For example, look here, there's lots of code and scripts I have written for Altera tools:
    http://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html (http://www.ovro.caltech.edu/%7edwh/correlator/cobra_docs.html)
    Altera does not consider this illegal.
    Cheers,
    Dave
    Hi Dave,
    Thank you for your reply, it really helpful. But, I got two more questions. Do you know which version of Modelsim that Quartus II 7.2 web edition should work with? Does there exists a QXP file for project under Quartus II 7.2 web edition? I cannot find that file in my project folder:-( Thanks.
    --- Quote Start ---
    --- Quote End ---
    The FTP site no longer has the Altera Starter Edition file associated with 7.2
    ftp://ftp.altera.com/outgoing/release/
    However, you should really upgrade to the latest version of Quartus. If your design is written using VHDL or Verilog, it will work fine.
    --- Quote Start ---
    --- Quote End ---
    No idea. I don't use them.
    Cheers,
    Dave
