10 years agoQuestion about good design: overriding functions, function parameters or similar
Is in VHDL something similar to overriding a function or giving function as parameter to an entity (similar to c++ or javascript). I'm implementing some image processing components which are similar to each other up to one or two functions which I use to calculate pixel values. I want to create one entitiy and provide different functions as parameters to this entity. I can't export signals and compute values outside of entity because function is used inside in several places, in for loops etc. What is the best way to implement this? My current idea is to create a large main function which calls other small functions according to parameter given to entity. The entity always calls the main function and gives a selection parameter.11 Replies
Without knowing more about your architecture it's difficult to give sound advice, but an alternative could be to use several entities. Your generic image processing module could be an entity, that provides an interface for an external "pixel processing" entity. Then create as many pixel entities as you need and connect the right ones together as you need them.
