10 years agoQuestion about good design: overriding functions, function parameters or similar
Hi, Is in VHDL something similar to overriding a function or giving function as parameter to an entity (similar to c++ or javascript). I'm implementing some image processing components which...
10 years agoWithout knowing more about your architecture it's difficult to give sound advice, but an alternative could be to use several entities. Your generic image processing module could be an entity, that provides an interface for an external "pixel processing" entity. Then create as many pixel entities as you need and connect the right ones together as you need them.
