9 years agoQuestion about Example 1-22 of Quartus Prime TimeQuest Timing Analyzer Cookbook
In Example 1-22 of "Quartus Prime TimeQuest Timing Analyzer Cookbook", the latency of clk_a and clk_b is specified. clk_a and clk_b are in the different clock_groups. However, if is normal that they are not used in set_input_delay and set_output_delay. Why should the latency and clock_groups for clk_a and clk_b be specified if they are used in the set_input_delay and set_out_delay?
Also set input_max [expr $Td_max + $Tco_max] set input_min [expr $Td_min + $Tco_min] # Create the input delay constraints when clk_a is selected set_input_delay -clock virtual_source_clk_a -max $input_max [get_ports datain] set_input_delay -clock virtual_source_clk_a -min $input_min [get_ports datain] Are there the differences in the clock paths missing in $input_max and $input_min? ThanksNo RepliesBe the first to reply
