9 years agoQuestion about component and packag
Hello, I am new to VHDL. I have a question about using a component in the package body which is defined in package head. But there is error about the port map in the package body. Could anyone help me on this? Thanks.
the code is something like following:library ieee;
use ieee.std_logic_1164.all;
use work. comparator.all;
package func_pkg is
function compare (a, b: in std_logic_vector(3 downto 0)) return std_logic_vector(3 downto 0);
component comparator
port( in_a: in std_logic_vector(3 downto 0);
in_b: in std_logic_vector(3 downto 0);
alb: out std_logic
end component;
end package;
package body func_pkg is
function compare (a, b: in std_logic_vector(3 downto 0)) return std_logic_vector(3 downto 0) is
variable result : std_logic_vector(3 downto 0);
variable sig_l : std_logic;
begin
cmp: comparator port map (in_a => a, in_b => b, alb => sig_l);
if (sig_l = '1') then
result := a;
else
resutl := b;
end if;
end function;
end package body; where comparator is the component which input a, b and return 1 if a<b.No RepliesBe the first to reply
